Hey fellas long time no see....been hell around here for the past few months when I get a sec I'll fill ya in. In the meantime
I changed my plugs the other day and 1&4 were nasty, black and gummy. Number 2&3 were pretty and white..wonder whats up? it was the same thing the last time I changed
Wonder if the rings are not seated
Any ideas?
=====Justin=====
Spark plugs
Spark plugs
1987 Tercel 2WD, 1983 Tercel 4WD
How would only two of four piston rings not seat? It seems to me it would be all or none. Have your recently rebuit the engine? Rings seat within the first 100-500 miles of driving on new rings.
Bad valve stem seals could cause this on the 1 and 4 cyl. Or incorrect temp range on the spark plugs, are all four the same type of spark plug? Also try testing, or just swaping out the spark plug wires, 1 and 4 might be bad.
There are more searious problems that could cause this too. Do a compression test on the engine and get back with us if either of the above yield nothing.
I guess number 3 plug can run lean, but a couple of oily or gummy ones along with the two clean ones would have to indicate something wrong with those 2 cylinders? Probably oil? Maybe fuel. Maybe they aren't firing right...plug wires?
I'm sorry I take for granted all you fellas know the history on my old girl. Less than a year ago I installed a brand new 4A....dropped on a Weber few months later blew the head gasket. Had the head checked by the machinist was told it was perfect, like brand new. Replaced the gasket and all the jazz that goes with it. has new wires, no smog crap at all,
Zruns like a champand pulls like a mad ox but every so often it misses a little and I end up changin the plugs to find the same thing 1 & 4 are gummy and 2 & 3 are beautiful.
=====Lollypop=====
=====Lollypop=====
I think petros is right, a lot of things could lead to this. An inspection under the valve cover (i think the seals can be accessed by just removing the cover, am i right guys?) should clear this up, & the gasket on the valve cover is reusable, so dont worry bout a new one.
1984 2wd wagon, "bottle rocket": http://www.myspace.com/1984tercel
1995 Isuzu TFR-S, "Shorty": no cardomain page yet
Seals are made of rubber. They can go bad without the actual head being bad.
oops. i did not notice that. sorry for my lazinessLollypop wrote:Well this problem is going to take more than a valve train inspection. Maybe you missed the part about having the head checked by a trained machinist when I replaced the head gasket.
Are you from Mobile originally?
=====Lollypop=====
& yes, i originally lived in Midtown mobile for 15 yrs, but 3 years ago i moved to Citronelle (small town 30 mi. N of Mobile).
Why do you ask?
Well I noticed when you hit the Tercel4WD scene that you were from Mobile, so I mentioned you and I could get together and talk Tercel. You didnt seem very interested so that just made me notice your name and post when I come across them. As I have read your posts ...you just didnt seem to be one us. Just an observation.
=====Lollypop=====
=====Lollypop=====
misfiring?Lollypop wrote: but every so often it misses a little and I end up changin the plugs to find the same thing 1 & 4 are gummy and 2 & 3 are beautiful.
=====Lollypop=====
