slush box
slush box
Anyone with TERCEL Automatic transmission experience. My concerns. I'm looking to purchase an 85 4WD DLX with 142,000 miles on him and a bad automatic transmission. I've only driven and worked on the manuals. Does the automatic 4WD have a EL to go slow in 4WD and also..How does an automatic respond power wise compared to the g-force maximizing manuals?
new purchase 87 DLX Wagon FWD 126,000
Daily Driver 86 SR5 4WD 252,000 miles and rolling
94 Previa 175,000 Sold
93 Corolla 248,000 Confiscated
past 86 DLX Wagon FWD 298,000 rusted away
85 Wagon FWD 195,000 T-boned and expired
how bad is the tranny? sometimes a full flush does wonders.
do it my way though.
run engine flush through it for 5 min, then drain the pan and refill, remove the line sending fluid to the cooler and put it in a bucket, start engine and top it up as old fluid is being poured into the bucket, after it turns clean, stop topping it up and wait until air bubbles start coming out, shut off the engine. re-attatch everything and then top it up to the proper level.
If the trans still works well enough to get down the road...flushing might get some more miles out of it. I'd also finish with Mobil synth ATF and some Lubegard additive.
Well I went to get the Tercel with the automatic. It was in pretty sad shape with rust holes, cracked windshield, really banged up rear quarter panels and dented in around the tail lights. It is not a rebuilder in my estimation.
Still looking for a project.
Thanks to all for your input and advise.
Don Jorgensen wrote:really banged up rear quarter panels and dented in around the tail lights.
like this?
viewtopic.php?t=2852
some say it will cost too much but i think it would be ridiculous to have a $900 stereo system, DVD player, Leather seats & a 4age swap with a dent in the side.
just my $0.02
1984 2wd wagon, "bottle rocket": http://www.myspace.com/1984tercel
1995 Isuzu TFR-S, "Shorty": no cardomain page yet
I'm talking about rust through holes in lower doors, rocker panels, holes in the lower post area between doors, and major dents that altered the profile of tail lights. The rear hatch was no longer aligned with the altered body although the owner said it did not leak...
ouch.. i would not drive that in fear of a damaged frame or drivetrain (although it is not common, it will happen to some tercels)Don Jorgensen wrote:I'm talking about rust through holes in lower doors, rocker panels, holes in the lower post area between doors, and major dents that altered the profile of tail lights. The rear hatch was no longer aligned with the altered body although the owner said it did not leak...
