on a related note....i have noticed there is a sensor on all of the vacuum diagrams i have seen on this forum have 2 or 3 lines running to it, the one on my engine only has one. any ideas?
I recommend pulling the top timing belt cover off, and cranking your engine a full 360 while inspecting the belt. Look for missing teeth, cracks, or other bad wear. Check that the cam timing is right (check FSM if you don't know how to do this). Also, buy/borrow a timing light, and check that your ignition timing is right.badmechanic wrote:Sweetness yesterday! it now idles again, but it kinda diesels, and i noticed when i cut it off(air breather off) fumes came out of the carb in a puff of smoke. so ideas? i'm gonna check the timing but i'm waiting on a 1/2 inch drive from neighbor.....but if yall get any ideas or if coltarms maybe take a few pics of his lines for me, i checked the other pics, and color diagrams they were pretty to say the least, but none of them put it all together, even using all of them together, i have lines in places none of the pics show. thx for tryin to help me you guys i really applicate it just had so say that. after all i am a badmechanic
If you have a good key...good slots in the crank and pulley...and a good pulley...AND the bolt in snugged to specs...the whole assembly should handle most anything.badmechanic wrote:is it possible the pickup coil( i'm hearing from my neighbor the pickup coil is under the plate in the distributer) is causing the fully problem, and would it cause the balancer to break along they key way? I have had a similar problem, but with a ford, the whole sleeve broke on the balancer then, and the problem was a warped crank....did i bend it?
