This is the third time the seller has listed these items: He had started at $40, and is now down to $1, with no reserve! There is one bid on the instrument cluster.
http://cgi.ebay.com/ebaymotors/ws/eBayI ... 0073866474
'86 SR5 Instrument Cluster & Shroud on eBay - in NC
it's mine now.works great!
simple swap as usual with toyota.
there is only one jeep.and that is one too many!
Whatta Big Spender !
You got a deal for $2.25 and postage.
Way to go !
Way to go !
how does the swap go anyways?
my tercel has NOTHING attatched to the dizzy tachometer pick up, i'm convinced i'll have to run that wire myself.
I did notice a spot in the cluster plug where a wire was missing.
Mootsman and a few others have done this, I believe. They've said it was a snap - so to speak...
it is a simple swap, just unplug the old one and plug in the new one. the only issue i've found is that at some point in the early '85 run, they changed the cluster to a 110mph as opposed to 85mph. i put one from an '84 into my '86, and my miles per hour is way under the actual speed.
