My Cable clutch it’s brake constantly, the last that I buy (4 months ago) is SBK Japan but it break too…
What reasons may it possible…??
i have a big problem with my cable clutch
Tercel White 4Wd '83 a friend.
TOYOTA don't use it, mistreat it.
Visita mi blog en español:
http://tercel4x4.blogspot.com/
i make my own, i have to because the plastic part that adjusts the clutch broke on mine so i use the cable sleeve and i buy cable abd have a couple of spares in the car just in case ti change every thing i just need a 1/8 allen and the cable
i will to do the same if it persist, in my other tercel i was using a cable of VW and it have a nut with adjust... thanks
- Mattel
I replaced my cable the other day as mine snapped little by little over 6 months or so as I was tightening it more and more towards the end. then it finally gave away 1km from home..I drove it home in first and turned it off at the lights.
Then I found that the LHD cars don't have anything like the set up on the OFM. I had to take the clutch pedal off in the end.. All good now though..
I have a special after market plate on my firewall to stop the cable pulling through.. I think this is a common prob on LHD cars. If anyone needs photo's and plans for this PM me
From the time that I post this I change two cable more... but this week end I was whit a friend checking this because the cable is brake again and we see that the two cable brake in the same point... and there are not friction whit a metal part but when he clean the pedal of the clutch he look several little pieces of metal inserted in the plastic.... sure of old cables... this little pieces of metal was cutting little by little the new cable...
the little pieces of metal was here...
