emission control garbage
raybbaby
Post by raybbaby »
wondering if anyone has or can point me in the directon of any kind of instructions or diagrams of all the little hoses that come off the carburetor. The car is a stock tercel (83) with the 3ac. I recently had to pull the carb for a head gasket repair and when I re-installed it I've got everything hooked up except for two little nipples on the drivers side directly under the bowl, and a spring on the throttle cable pulley that is not the throttle return spring. Any help would be much appreciated. :x
viewtopic.php?t=692&highlight=vacuum
Check out the FSM available for a download.
raybbaby
thanks
Post by raybbaby »
This was just the thing I needed! Thanks a lot, my baby is back on the road! :D
