Headlight Buzzer
Headlight Buzzer
I have a tendancy to leave my lights on. I leave for work and it is dark I get to work and it is not so I do not notice them.
Is there a buzzer in our cars that someone might have removed or that might have worn out?
I see I post for a door buzzer and that gives me hope.
<span style='font-family:Optima'><span style='font-size:8pt;line-height:100%'><span style='color:green'>1984 SR5 4WD gold 140k miles running superbly on new clutch</span></span></span>
Ogedei -
A friend had this same habit some years ago.
His solution was to put a tiny Velcro dot on his instrument panel and another on a small plastic card he made up bearing the reminder "Turn off lights". Actually, his reminder was much more graphic than my stated message, but you get the idea.
I also used to do something similar when I used a bike roof rack on my '83 SR5 back in racing days.
I think JCWhiteny has a lights on warning gizmo they sell...but what don't they sell!
Or go to RadioShack and buy a 12V LED...run one leg to ground and the other to a wire going to a headlight...then when your lights are on...it will be on.
I have found a quick solution but I need to know "a ground point that is only grounded when the vehicle is turned off" on Civics it si the defrost fuse
Does anyone know where that is in our cars?
You could grab the headlight circuit out of a corolla gts or mr2 or cressida (and maybe others) that automatically shuts the lights off when the car is off and you open the drivers door. Personally I like these the best. Not sure how tough it would be to wire in though.
Current:
91 LJ78 Landcruiser EX5
95 A32 Maxima SE
Former:
87 AW11 MR2 Smallport 4AGZE
93 Taurus SHO ATX
86 AL25 SR5 6spd 4wd
90 AE92 GTS
82 KP61 SR5
85 MX73
87 AE86 GTS 4AGZE
85 AE86 GTS
83 AL21
95 A32 Maxima SE
Former:
93 Taurus SHO ATX
90 AE92 GTS
82 KP61 SR5
85 MX73
87 AE86 GTS 4AGZE
85 AE86 GTS
83 AL21
I have thought about the door thing but I do not have a door sensor so I would have to put one in, adding more effort.
I have a more complicated write-up that I will create if I can find a circuit that is ground on the car being turned off.
I will post a write-up when I am done.
breaking it down this afternoon I found that we are not lucky like Honda civic owners who have a readily available ground when the car is off.
So adding a light is no problem I can even follow the rain gutters in the car and run the waire inside from the outside if I do not find an easy way to go through the firewall.
Getting the relay to work has been hell but I am going to research research reseach
If you want an easy way to do this, all you need to do is find a buzzer (or light), wire the pos to any light that is on when the lights are on (ashtray, stereo, etc,), then wire the ground end into the door pin-switch (either from the switch itself or the lead going to the domelight), and VIOLA! If your lights are on the buzzer (or light) will come on when you open your door. Ogedei, if you don't have a door switch, they are sooo easy to install, it is almost a crime. There are some that you just drill the hole and they self-tap in. They have long enough leads that you could feed them in and find them easilly behind your kick panel. Besides, I can't think of a circuit that would be grounded with a key off only situation. I'm not saying there isn't one....I just can't think of one.
I used the lead that used to illuminate the stereo in my Corolla to wire the toggle switch to my fog lamps. Since the lights turn off when the key is off and door is opened, I can never leave my fog lamps on.
Fingers
Fingers
Helliphino.com
Helliphino.com
I may look into the door switch since I could not find a way to get the relay to work. not sure why they relay would not trip no matter what circuit I tried.
I think it might have had a trouble with the headlights being 15 amp and basically everything else was 10 or under.
So I think if I put an fuse inline and lower the amperage to 5 amp I can use any of the other circuits and maybe use the relay without a door switch.
I have a light hooked up now. Positive attached to the power side of the fuse and negative attached to the frame. The light is on when the lights are on regardless of the car being off or on. I will post pictures when I have finally given up on the relay buzzer.
