oilpan gasket
T-Bone
oilpan gasket
Post by T-Bone »
I was wondering what has to be done to replace the oilpan gasket? I was looking under my tercel and I noticed that there is like the cradle thing that the engine sits on covering the oil pan. Is there room to work around it?
Daily Driver:
1988 Toyota Tercel SR5 4WD
3AC 2BBl Downdraft Carb
Project Car:
1993 Honda Del Sol Si
D16Z6 Head/Block
D16A1 Pistons (C/R 12.3:1)
Gasoline Fumes
Post by Gasoline Fumes »
I think you have to pull the engine. :shock:
T-Bone
Post by T-Bone »
yeah, i was kind of thinking that :(
Daily Driver:
Project Car:
D16Z6 Head/Block
waynehoc
Post by waynehoc »
Haven't done this myself, but doesn't look like you need to pull the engine. The procedure is covered briefly on pages LU-4 and LU-5 of the FSM, and also covered on the AutoZone site here http://www.autozone.com/servlet/UiBroke ... 1b7a07.jsp
If it leaks a little...best bet is to snug the bolts down just some...I'd use a torque wrench so you don't overtighten them.
If someone has overtightened them...even a new gasket might not help much.
I've had the pan off of an auto trans at least 5-6 times and use the same gasket over and over...no leaks.
T-Bone
Post by T-Bone »
takza wrote:If it leaks a little...best bet is to snug the bolts down just some...I'd use a torque wrench so you don't overtighten them.
ill check the bolts and see if they are tight. when you took your pan off did you have the engine out or was it still in the bay?
Daily Driver:
Project Car:
D16Z6 Head/Block
Gasoline Fumes
waynehoc wrote:Haven't done this myself, but doesn't look like you need to pull the engine. The procedure is covered briefly on pages LU-4 and LU-5 of the FSM, and also covered on the AutoZone site here http://www.autozone.com/servlet/UiBroke ... 1b7a07.jsp
Guess I was wrong. :oops:
