5th gear z54f 4wd wagon 1986
Smithbauers480
My tercel:: 1986 Toyota tercel wagon 4x4
Post by Smithbauers480 »
Hello! New to the forum. I'm in need of a 5th gear assembly if anyone could help. I wish there were more tercels around but most are gone from salvage yards here in Tennessee. Thanks
Re: 5th gear z54f 4wd wagon 1986
Hi, and welcome to the forum. Do you have your transmission disassembled, and is it just 5th gear you need?
Smithbauers480
Yes. Trans is disassembled. The gear is in 3 pieces. Also the front spring clip, and plate r destroyed.
Ok, good stuff. Are you on facebook? That will probably be your best bet for finding the parts you need. There is a fb group for 4wd Tercels that is much more active than this forum is nowadays. Most of the regular posters from this forum also use that group, plus there are tons of other folks there too. Robert Walker is located in WA state and he has quite a collection of trans parts so he might be able to help you out. Luke Anthony is another one who has a good collection of parts but I don't know if he has as much transmission internals as Robert. Anyway, my suggestion is to join that group and make a post like you did here, Robert will likely see it and let you know if he has what you seek.
If you don't have FB, you can message Robert through here. Here is his profile:
memberlist.php?mode=viewprofile&u=274
Just click on 'send an email' or 'send a private message' and he should get either of those.
Good luck!
Smithbauers480
Great! Thanks for the info...
