Battery light wont go out but battery is charging
Leo Johannes
My tercel:: 1985 toyota tercel 4wd wagon. I have done zero modifications exept repairing some rust
Post by Leo Johannes »
My tercels battery light won’t go out but my battery is charging. I can find nothing wrong with the charging the battery ans alternator is new. Could it maybe be the ic regulator?
Paul
Re: Battery light wont go out but battery is charging
Post by Paul »
Check the battery voltage while it's running at idle in neutral. If its above 15 volts, the light can come on to warn you that the battery is suffering.
Leo Johannes
That ia not the problem, it began to light wgen the alternator and ic regulator broke but after changing those it is still on
What is an IC regulator?
There are two types of alternators for these cars: internally and externally regulated. Most of them are internally regulated. I have heard of people accidentally putting in the wrong type of alternator and having problems from that. Could that be a possibility here?
