Sway bar 1985 Tercel SR5
henrygun
My tercel:: 1985 SR5 Tercel
Post by henrygun »
I need a sway bar for 1985 Tercel SR5
does anyone here have any leads?
im based in Brooklyn NY
Thanks
Re: Sway bar 1985 Tercel SR5
HG,
If you’re referring to the rear sway bar, I should have one, but not the links for connecting it. With heavier rear springs, I don’t miss the sway bar.
There is also the bar in the front for the control arms that may be called a sway bar, which are you looking for?
henrygun
Post by henrygun »
Hi Chris,
Thanks for your reply
Im looking for a front swaybar. The end snapped off when replacing the control arms.
If anyone has a front swaybar or knows a good person to make one, let me know
Henry
HG,
Salvage yards would be your best bet. If you visit the unrelated FB page, Luke Anthony and Timothy Thomas are the goto guys. If you’re not on FB let me know and I can reach out to them for you.
It seems these bars may be “spring” steel, so getting one made would likely be cost prohibitive.
MrWrench
Post by MrWrench »
I have one. I will not be able to remove it for a few weeks because my parts car is buried in snow, sadly.
1983 AV-II Sprinter Carib.
