at the very least, a nearby Forum member should snag the composite headlight assemblies, which are unique for only the 1987 and 1988 models... I'm assuming that they're the same for both the 2WD and 4WD wagons from those two model years, but don't know that for sure...
lens looks cracked or broken on the driver's-side headlight, but would still be worth getting because the headlight frame and clearance light look intact and are becoming exceedingly hard to find
https://row52.com/Vehicle/Index/JT2AL32V1H3669290
'87 DLX 2WD Tercel wagon added to wrecking yard in Rancho Cordova, CA on 8/18/2023
- garyfish
Re: '87 DLX 2WD Tercel wagon added to wrecking yard in Rancho Cordova, CA on 8/18/2023
Head lights and front sidemarkers are the same on FWD and 4WD. Only the grille is different (but interchangeable.)
