Free: Parts Collection, GONE to a true gentleman
Re: Free: Transmission, vast parts collection
Hubcap collection ?
Used master cylinder, worked perfect in car parted out, caliper
front strut rubbers and rings
brake petal mechanism, or clutch?
brake hardware
heater control valve
various hoses
3 hatch wiper motors, 2 pushrods
3 front wiper motors, pivot bracket
brake hardware
various hoses
Re: Free: Transmission, vast parts collection PHOTOS below
NEW PARTS IN BOXES
4 timing belts
2 timing belt tensioner bearings
3 front wheel bearings
2 front caliper brake repair kits
2 rebuild kits – rear brake slave cylinders
2 distributor rotors
3 alternate rotor brushes for rebuild
6 fuel filters
5 PVC valves
6 front drive axle seals
2 timing cover seal tc915
6 front axle seals 052-3521
4 camshaft seals 052-3178
4 wheel seals 052-2136
1 OXYGEN sensor
2 front brake hydraulic flex hoses
2 rear brake hydraulic flex hoses
3 rear brake slave cylinders
3 brake/clutch petal rubbers
2 pvc grommets
3 distributor O rings (oil seal)
5 water outlet gaskets
1 wheel bearing retaining spring
6 thermostat gaskets
3 EGR gaskets
1 front camshaft seal
2 water pump gaskets
3 extension seals transmission
10 transmission output seal
3 input shaft seals
Box 13 topped off with gaskets
6 crankshaft front seal gasket sets
2 rear main bearing gasket sets
2 intake/exhaust gaskets
1 head gasket
1 valve cover gasket
1 carbeurator gasket kit contains 3 gaskets
3 oil pan gaskets
4 timing belts
6 fuel filters
5 PVC valves
1 OXYGEN sensor
2 pvc grommets
3 EGR gaskets
3 input shaft seals
1 head gasket
3 oil pan gaskets
Stored in long light tube box
windshield trim
random SR5 side trim
both front doors, window track guides with window seals
door window sills
Complete? Rubber set all 4 doors and hatchback
6 hatch support pushrods
1 of each side, mirror bracket / front window track channel
more SR5 trim, jack sets
windshield trim
door window sills
4 partial and complete Distributors
2 new distributor caps in boxes
3 ignitor modules (removed from other distributors
6 wire cap snap-on spacers
Vacuum advances,
water tanks, squirt motors
3 starters, 5 alternators varying versions
2 radiator fans,
1 A/C condenser with fan
2 power steering pumps, one pulley to add power steering belt
1 unknown, perhaps in the EGR line from catalytic
Vacuum advances,
2 radiator fans,
LEFT FRONT, 100% rust free
View under wheel well, no rust
Power steering rack, upgrade to have it
Power steering hydraulic line set
TVSV's and a gas filter
A/C throttle booster
head hot water input/output fitting
water pump outlet, riser tube and temperature sensor
4WD Badges
steering cowlings various
dash vent panels
radio housing (with clock built in see the wire) and mounting brackets
Assorted switches, handles, snaps window trim corners, rubbers, hatch squirters, gas caps
A/C belt tensionersA/C throttle booster
4WD Badges
dash vent panels
Pristine hatchback, no rust
sway bar in front rust/corrosion free
unknown suspension equipment
random brake metal, some measures within tolerance
2 radiator fans
1 A/C condenser and fan
2 power steering pumps, 1 fan pulley (to add on a car without it)
These parts are F-R-E-E for whoever takes my entire collection
4 timing belts
6 fuel filters
5 PVC valves
1 OXYGEN sensor
2 pvc grommets
3 EGR gaskets
3 input shaft seals
1 head gasket
3 oil pan gaskets
4 timing belts
6 fuel filters
5 PVC valves
1 OXYGEN sensor
2 pvc grommets
3 EGR gaskets
3 input shaft seals
1 head gasket
3 oil pan gaskets
sorry for the repeats
Lost track of what was already posted..... Sorry
Re: Free: Parts Collection, continue to page 2 !!!!
Holy toledo. That's an incredible collection. Can't believe you're giving it away, but I guess those of us who would actually take it are few and far between. I hope someone takes you up on it soon!
This reminds me, I had a similar situation with my ae95 Corolla about 7 or 8 years ago. My basement was full of spare parts for it but the person who bought the car didn't want them. I posted them online for a while but had zero interest. They all ended up going to the dump, and it broke my heart.
Thank you member 'dlb' for your understanding, you nailed it, it's personal.
Much effort and sweat went into this collection back in the days, 2010 through 2016
NOW I am 100% into it all being gone in one move, to make it easy, I don't need the money.
Hoping some of this will be used, or resold to Tercel people, rather than becoming scrap metal.
As of now almost everything's photographed, moved into garage, smaller things are in bins to go.
I'm eager to get the car back in the garage.
*** DEADLINE / moving time is weekend of August 5-6
Collecting offers up to deadline, the more personal situation details the better, sell yourself.
free pickup of all leave nothing behind.
*** SECOND CHANCE, August 7 through August 14 Sunday - if nobody takes all....
-- $200 to come get transmission and differentials.
-- $50 to take both radiators, one looked brand new when I found it at the pick'n 'pull
-- PM cash offers for other specific items.
*** August 15th metal recyclers welcome.
*** PM requests, for smaller items easily mailed.
.....Anything in high demand will then be saved and made available on EBAY
- SirFoxx
100 shipped for all carbs?mrdance123 wrote: Fri Jul 21, 2023 1:15 pm Thank you member 'dlb' for your understanding, you nailed it, it's personal.
viewtopic.php?t=16285
1982 4dr Tercel (RIP)
- My tercel:: 85 SR5 4WD Jeep coils, air shocks, weber carb
PM sent yesterday
I’ll take it if you still have it.
