Hello--
I am need of a drivers side mirror for my '85 2dr hatch. I shut the door and the glass fell out, exploding on the ground.
Thanks!
WTB Drivers Mirror
- SirFoxx
WTB Drivers Mirror
viewtopic.php?t=16285
1982 4dr Tercel (RIP)
Re: WTB Drivers Mirror
Mirror looks different from our wagons- good luck!
- SirFoxx
only difference is they dont have the lever. they are all compatible with one another.
- garyfish
I believe the driver's side has a flat mirror -- not a special convex mirror like on the passenger's side -- so you should be able to go to an auto-glass business where they can cut a new mirror to fit and then use their special adhesive to mount it in place. You don't even need to remove the mirror housing to have this done and, if my memory serves me, it's relatively inexpensive. Good luck!
- My tercel:: 1985 Toyota Tercel 4wd Sr5, Fed emission but no cat converter. Manual transmission, with air conditioning.
Check rock auto, I just installed a new mirror glass from them and it's working perfectly so far
