4AGE connecting rods in a 4AC
Cadendoo22
My tercel:: 1983 Toyota tercel sr5 4wd
Post by Cadendoo22 »
After my 3AC spun a bearing I decided it was a good time for a 4AC swap. Turns out the motor I bought had also spun a bearing. So after talking to the junkyard about warranties and such ive decided to rebuild the 4A. The problem is that the last piece I need is connecting rods, all 4 to be exact. Since i cant find anything for sale online, my question is, can I use the connecting rods from a 4AGE in my 4AC.
Cadendoo22
Re: 4AGE connecting rods in a 4AC
Also forgot to ask if the 3AC rods will work?
SirFoxx
Post by SirFoxx »
3ac yes if its from a later 3a, 4age no. 4age has a bigger floating small end bearing whereas the 3ac/4ac is a press fit
viewtopic.php?t=16285
1982 4dr Tercel (RIP)
you might be able to make them work with the help of a machine shop, but there were some differences. as I recall the 4age used forged rods, so those are stronger and better than the 3a/4a rods. but you will also have to check the length and the small and big end dia. to verify. the 3a and 4a rods are the same as I recall, cast iron, both small and large end are the same. the early ('82-83?) 3a rods have different size large end as I recall. but the later ones are the same. best bet is to get them side by side and take a micrometer or caliper to them and check everything.
