Troubleshooting Non-Functioning Instrument Lights
- My tercel:: 1984 SR5
Fuses all seem good, I pulled the instrument cluster and cleaned it, checked the bulbs, the works. The High Beam indicator and both turn signals are working fine. I understand that it could be the wiring, although I am very skeptical of that as everything seems to be in great shape all across the car. I think if anyone has access to a 1984 SR5 wiring diagram, it likely would be the most useful. Any info would be great!
Re: Troubleshooting Non-Functioning Instrument Lights
Is it just the lights in the dash cluster? I can't remember which fuses are where but there are fuses in a few different locations, have you checked the fuses in each of those? My next guess would be a bad ground, which is always a wonderful PITA.
Have you checked the rheostat control for the bulbs? Do the illumination bulbs for the heater controls work?
I can't say for certain if the heater control bulbs work or not...the inclinometer bulbs do not, however the dome lights are functional. I'm very intrigued by the rheostat being an issue tho because I noticed that when I put the final few pieces of dash trim on the other day, the rheostat is not lined up in the center of its slot, and additionally I realized that the drivers side dash is not flush with where the heater vents meet, if that makes sense. I suppose I will pull some more screws out tomorrow and keep digging!
I checked the Fusebox under the drivers side and the one under the hood. I may go back through and check every fuse under the drivers side, as I only checked ones that I though might be remotely relevant to instrument lights.
The initial dimmmer knob test is easy -- just turn it! If they don't come on, remove the trim panel and make sure the wires are connected to the back of the dimmer. If the dimmer itself looks suspect like you mentioned, check for voltage both coming in and going out of it.nightcrawler07 wrote: ↑Sun Apr 24, 2022 1:38 am I can't say for certain if the heater control bulbs work or not...the inclinometer bulbs do not, however the dome lights are functional. I'm very intrigued by the rheostat being an issue tho because I noticed that when I put the final few pieces of dash trim on the other day, the rheostat is not lined up in the center of its slot, and additionally I realized that the drivers side dash is not flush with where the heater vents meet, if that makes sense. I suppose I will pull some more screws out tomorrow and keep digging!
Or just connect the dimmer wires together, thereby bypassing the dimmer and the lights should be full bright.
The issue was indeed the Rheostat. I don't know if it was actually bad or not, but it was missing the plastic female piece of the harness. It appeared as though the terminal prongs were bent out of alignment because of this. I was able to pull a rheostat out of a 2wd tercel at the local junkyard. the instrument cluster looks great!
Great job, thanks for letting everyone know.
