'87 2WD DLX wagon added to wrecking yard in Kansas City, MO on 1/1/2020
garyfish
Post by garyfish »
by now I must sound like a broken record whenver an '87 or '88 Tercel wagon shows up on Row52.com ... and I'll continue to do so because I'm still in need of the unique headlamp assemblies that fit these 2 model-years only... I need both the driver's side and passenger's side assemblies to make my '87 T4WD DLX wagon whole again :)
if any Forum member near Kansas City checks out this vehicle and it has one or both headlamp assemblies in decent condition, please grab them!
https://row52.com/Vehicle/Index/JT2AL32V9H3669909
Happy New Year to all, no exceptions!
Re: '87 2WD DLX wagon added to wrecking yard in Kansas City, MO on 1/1/2020
Gary,
Dairmait and I texted about this one earlier, I believe we both have auto alert through Row52.com.
I assumed the grills were different enough that the two wheel drive headlights would not work for a 4WD. I'm not sure what my weekend holds, but will let you know if I get a chance to retrieve the headlamps.
rer233
My tercel:: Multiple
Post by rer233 »
Headlight ass'ys ARE the same. Grills are different (but interchangeable.)
garyfish
Post by garyfish »
Thank you NWMO!
and, thanks to rer233 for the info on compatibility of the headlight assemblies between the 2WD and 4WD models!
Hey all,
Reasonably successful day at KC Pick-n-pull. Pleased to collect some of the small plastic grill clips as well.
BaileySims
Post by BaileySims »
That's a really good looking cargo cover!
WAGON MAFIA.
Blood, sweat and beers.
Hey Bailey,
The gal ringing me up labeled it a “spare tire cover”, under $10.00.
And “Toad” (Tercel #2) is brown, though this dark brown may stand out against the 83’ plaid, will have to see.
PS - Did the FB fella wanting to lower his car make contact?
Hey all,
Another beautiful January day in MO (crazy), got some time with my parts car.
For anybody pulling a rear drum. If you don’t have the correct bolts to remove the drum, you can use two of the door hinge bolts. Got my driver’s side rear axle pulled as well.
SirFoxx
Post by SirFoxx »
NWMO,
Do you recall if it was a stick or automatic? If it's a stick, Im going to go pull the tranny to have as another spare for my '81 autox car.
viewtopic.php?t=16285
1982 4dr Tercel (RIP)
Hey Keegan,
Definitely a M/T car. I look forward to watching you race sometime.
SirFoxx
Post by SirFoxx »
NWMO wrote: Mon Jan 06, 2020 8:22 pm Hey Keegan,
Sounds good. I am waiting for tax moneyz to finish my build. Still need cams, cam gears, clutch, head gasket, knock sensor, fuel pressure regulator, figure out what fuel to use, break it in, then get it tuned. The high compression pistons really f***** the build haha.
