The FSM does not have a photo (or even an accurate drawing) of the entire tube, and mine looks pretty kinked at the bend by the block, under the oil filter. I would think that the final portion of the tube would be at 90 degrees from the block, but mine is off by quite a bit, leading me to think that it was bent back at some time, leading to the pretty good kink at the bend.
It still sucks (some) air, but would obviously suck more if the kink were a normal full-diameter bend. I just do not know if the quantity is important. It would be possible to cut the tube and just use a piece of rubber tubing to be the final piece.
Thanks to all respondees !
