Transmission problem/clutch?
PNWtercel
Post by PNWtercel »
I have a 85 and I was driving along just fine then I lost my gearing and coasted to a stop car still starts and runs fine just no forward movement
I can shift through all the gears fine but the car will only move when I am in reverse
Any ideas?
I appreciate it
Re: Transmission problem/clutch?
sounds like an important part in your transmission gave up. Bummer.
have you put it in 4wd and tried to drive it? sometimes if the output shaft to the front diff fails, or the spline shaft on one of the cv axles fails, it will act that way. Putting it into 4wd and have it drive forwards indicates you may only have to replace a failed CV axle, or perhaps the front diff input shaft.
There are threads on this topic.
Odd it has reverse, might be dumb luck, but the trans has to come out either way to diagnose/fix it.
though it is worth checking your cv axles, remove them first and make sure you have the all of the spline shaft at both ends still attached. these have to come out anyway to pull the transmission, so when you remove them, if you find one of the spline shafts at either end sheared off, all you have to do is replace that CV axles.
forum member Xirdneh may have the parts you need to fix it, or might be able to fix the trans for you if that is what it needs.
PNWtercel
Post by PNWtercel »
Thanks for the reply I did try putting it in 4wd it did not move
I took a quick look at the cv axles and the driver side looked like one I have never seen before and also looked like it was pulled out a little
But the passenger side looked normal would the car move if just the passenger side cv axle was engaging?
when axle one breaks, the diff just spins around the other. it will not move with just one axle. but it will move in 4wd through the rear axles. so it sounds like you are gong to have to pull the transmission.
PNWtercel
Post by PNWtercel »
One more thing is that there is a loud whining noise when the car is running but the sound goes away when I depress the clutch
likely related to the trans problem. when you depress the clutch pedal you disengage the trans from the engine, a whining bearing will stop rotating.
input shaft on tranny causes that type of whining usually because you have low oil in tranny
low oil is the main cause of blown gears
drain the oil
if you come up with less than 2 quarts I will bet your gears are gone
if you drain the tranny oil the magnetic drain plug will have pieces of metal attached if the tranny gears blew out
check that first
