4wd manual transmission mount
https://www.yoyopart.com/oem/11999399/anchor-8377.html
Hey all,
Any help finding a source for one of these?? I assume worst case, a person could purchase a 2WD mount w/o the flat “ear” and add it.
I don’t know that mine has to be replaced, just trying to do all I can while swapping engines.
Hey all,
Re: 4wd manual transmission mount
Autozone says they have them, pic looks correct,
https://www.autozone.com/drivetrain/tra ... 6_0_0_3498
Haven't tried to order yet, the first place said they had them as well and then didn't.
Autozone is a tease as well, "out of stock".
5.00 mount from rockauto ,,change to 4wd mount
pic
- garyfish
jimcrazy's suggestion (above) sounds like the best and cheapest option available, particularly if you or a friend is handy with a welder
the only place online that I can find an actual tranny mount for our T4WD's -- the one that's asymmetrical, not symmetrical like most of them which are erroneously listed as being part # 12371-15070 -- is on eBay from a French seller, which will cost you over $100 US:
https://www.ebay.com/itm/Silent-bloc-TO ... XQBNlRhIzD
No problem fabbing one. I just wonder if the new mount would be better than oem +33 yrs, I can’t say I had any vibration problems, just seems like the time to sevice.
I sent an inquiry email on 12371-15070 to Indy's Butler Toy; will adv when an answer is recd.
Butler came through for me for various oddities for our guys when other Toy dealers had said "NLA."
Tom
Tom
Any updates?ARCHINSTL wrote: Tue Apr 24, 2018 1:02 am I sent an inquiry email on 12371-15070 to Indy's Butler Toy; will adv when an answer is recd.
Tom
Butler just called! The parts guy checked all of Toy's USA warehouses and said they were NLA. He did suggest emailing the oldest dealers in your area, giving them the part number, just in case there was one lurking on a way-back shelf.
He did not have access to Toy of Canada or Mexico, so those are possibities.
Autozone still lists the 4WD transmission mount with the correct photo, but once you get to the point of typing in your payment info, they mention that the quanity of "1" is more than they have in stock.NWMO wrote: Mon Apr 23, 2018 6:48 am Autozone says they have them, pic looks correct,
I wish they would just removed the part listing...
- Jonymoto
This is how I overcame the mount availability problem.
Cut and welded, or hammered into shape?
just zip the one side off old mount weld to the new mount
- Jonymoto
I removed the bracket from the old 4wd mount and welded it on top of the 2wd mount.
