Hello again, and thanks for the tips. I wasn't able to get after the fuel system like I wanted to this weekend but I did get the fluids and filters changed. I also scored a brand new 10 x 20 canopy from goodwill so I can work on the Terc in all this rain. I got in touch with xirdneh too and will be hopefully be able to swing my Terc over to him someday soon to have a lookover.
I made it to the parts yard and I was a bit miffed cause they had an 86 SR5 with 75k less miles than my DLX for only $95 more! I talked to the owner and he said I could have it next week for $700 if it's not sold by then. I'm less than two weeks into owning a Terc and I already want another...what kind of addiction is this?!
So I have a couple more questions...
First off, I thought that my power steering was low on fluid or something but now I'm thinking I just don't have power steering? Is that common on the DLX's? I googled and searched the forum but I couldn't find a good diagram of where the PS fill/reservoir is and I darn sure couldn't find it in my engine bay.
Second, I scored the SR5 cluster and it almost feels like a different car with the clock and tach in there! The only issue is that the temp gauge appears to be broken. Any ideas on how to fix it? It moves freely and jumps if I tap on the cluster cover. I'm wondering if I can open up the cluster and reconnect/fabricate something to get it working again? While I'm in there can anyone explain how to adjust the miles on the odometer without breaking anything? My Terc put on over 50k miles in an afternoon from the cluster switch and the math is getting too complicated for my brain.
I also got a nice new looking headliner with no sag from the parts yard so I'm scrapping the idea of recovering the old one. I'm curious, does anyone know if some slight condensation inside the roof is common? I patched all of the luggage rack holes in my roof with some good window flashing but there is still a tiny bit of moisture on the inside of the roof. Not large drips or drops but tiny little beads...I'm wondering if I should worry about it or not. I also found some well nuts at Lowe's so I'll hopefully be reinstalling the luggage rack soon. When I'm doing that I'd like to get rid of the rust around the holes. However, I've never really done any auto paint work. Do I just wire wheel/sand off all the cancer and coat it with a good primer then paint?
Lastly, the 83 parts car I'm pilfering has some decent stuff in there. Front seats are gone but the back seat is pretty nice...blue plaid. I grabbed the mud flaps if anyone needs a set. I also got the inclinometer housing and bracket but the inclinometer was already gone. Womp. I managed to pull the washer/light switches because it had the intermittent setting which mine does not. However, when I plugged it into my car the intermittent setting just acted like low. What else would I need to give my Terc the intermittent? The wiper motor?
Alright, that's all for now.
Thanks again.
