Do you just use one wrench to unscrew the inner tie rod end, or do you need to use a second wrench or some other tool to hold the steering rack while unscrewing it?
I've seen a few things on the Internet that seem to show that you just unscrew it without the rack being supported and I can't find any details in the svc manual.
Removing inner tie rod
Re: Removing inner tie rod
It's best to support the rack, I generally use a crescent wrench.
The flats on the tie rod end are narrower than most wrenches that size, I ended up buying a... 30mm? crows foot socket and then cut it in half to make it a thin wrench, works great.
- garyfish
I ended up buying one of those special tools to aid in removing the inner tie rod... can't remember where I bought it, but it was less than $15 and it worked like a charm
https://www.amazon.com/Inner-Install-Re ... mover+tool
- BaileySims
Don't forget about the locking tabs that you have to bend back to get them off. I made that mistake once.
WAGON MAFIA.
Blood, sweat and beers.
- My tercel:: 1985 SR5
It makes more sense now. Thanks.ARCHINSTL wrote: Tue Oct 23, 2018 8:49 pm viewtopic.php?f=2&t=3171&hilit=tie+rod
Read ALL, but scroll down a bit.
Parts should arrive around the 30th, so I hope to do this (weather permitting) the first weekend of November.
