Timing
- Defend_Dingo
- My tercel:: 86 4wd
Timing
Occasionally when I shut my car off it sputters and fires a few more times before finally shutting off. Is this a symptom of a timing issue?
I know the timing is probably off already because the previous owner did some hack job with the crank pulley because it was loose and it had about 10 degrees of free play in either direction (also the bottom timing dust cover is off so I can’t even see what it’s set at currently)
By the way does anyone have a crank pulley and/or bottom timing cover in good condition
How can I set the timing without seeing what it is?
Re: Timing
I have the bottom cover
is the crank pully loose because the vulcanized rubber broke free or because it is loose on crankshaft. if its crankshaft the key hole may be enlarged or crank chipped. in that case you may have to get another crankshaft.
- Defend_Dingo
Re: Timing
It’s loose on the crank, there’s a second keyhole cut into it so it can turn and lock in place (which is why it can rotate)xirdneh wrote: Mon Sep 24, 2018 4:45 pm I have the bottom cover
Whoever did the timing belt on it for the previous owner must have done something, they spot welded the crank pulley bolt onto the pulley, removed the timing cover, and then later the welds separated one day and I couldn’t figure out why the pulley started rattling all of a sudden
I put a washer on it and it’s tight now but it wobbles visibly as the engine is running
Re: Timing
"It’s loose on the crank, there’s a second keyhole cut into it so it can turn and lock in place (which is why it can rotate)"
i am not sure i understand this
sounds like the original keyhole in crank was bad so a new keyhole was cut and now its loose
is the new keyhole now bad too?
why would someone weld the pulley bolt to the pulley?
- Defend_Dingo
Re: Timing
with the bolt tightened down all the way the pulley would still be loose so the welded the pulley onto the bolt
- BaileySims
Re: Timing
Damn. I gave away my complete short block because I could find parts to put it back together. I do have a crank pulley, but it is a weird v belt style one. Let me know if you can use it.
WAGON MAFIA.
Blood, sweat and beers.
- Defend_Dingo
Re: Timing
Mine is the triple belt one, I don’t know what the difference is (mine is an 86)BaileySims wrote: Tue Sep 25, 2018 6:55 am Damn. I gave away my complete short block because I could find parts to put it back together. I do have a crank pulley, but it is a weird v belt style one. Let me know if you can use it.
- BaileySims
- Defend_Dingo
Re: Timing
I don’t know if it’s that the pulley / crank is worn, it fits fine but the bolt just won’t tighten the pulley to it (and it wobbles) so maybe the crank is worn
Re: Timing
you need to get the pulley off of it and get a look at the crank. there may be a way of repairing it on the vehicle, but likely sounds like you need to replace both the crank and the pulley. the 4a and 3a cranks are identical, so it is should be easy to find a replacement. Not sure about the pulley, you may need one from a 3ac engine.
Might be just as well to find a good tuning replacement engine, the 4ac (from corrolla) is more common and a bolt in replacement, gives you more power and a more reliable head gasket.
- BaileySims
Re: Timing
I pulled this one off the motor I found at the junkyard.
WAGON MAFIA.
- Defend_Dingo
Re: Timing
Yeah that looks like mine
Petros it’s working okay as is with the washer, but I would like to still check the timing which I can’t do due to the second keyhole
Re: Timing
Set the no 1 piston so it is all the way up. You can insert a screwdriver into sparkplug hole while rotating crank back and forth with a ratchet, you can feel when piston is at highest point. Then mark the pulley at zero with the timing belt cover marks.
- Defend_Dingo
Re: Timing
Can someone post a picture of their rotor position relative to the engine block? Mine is tilted back at a 15° angle it looks like, and my crank notch is at almost a 45 when the timing light goes off
(I know the pulley wasn’t rotated that much when I installed it)
