Shock Absorbers
hunter37
My tercel:: 1995 Toyota Tercel
Shock Absorbers
Post by hunter37 » Mon Jul 09, 2018 7:35 am
I would like to upgrade the shock absorbers on my 1995 Toyota Tercel. Is it compatible with Bilstein Shocks? I have read so many good reviews about the brand.
teranfirbt
Re: Shock Absorbers
Post by teranfirbt » Mon Jul 09, 2018 4:42 pm
Unless Bilstein lists them as an application then the answer is a "no, but". People have refit bilsteins for different applications into MR2's and such, should be possible to do it with your Tercel given enough fabrication/modification experience.
The real question is, what are you looking to gain? KYB Excel G dampers are reasonable quality and are (generally) a little stiffer than stock, so could be considered an upgrade.
Re: Shock Absorbers
Post by Petros » Mon Jul 09, 2018 6:15 pm
I know years ago many amateur racers wanted Bilstein adjustable on their rally cars, some even used them on their daily driver. They have a good reputation, though it seems a costly extravagance to use the adjustable shocks on a street car. those that used them said it was worth the expence, but I suspect that is what they told themselves.
those in the link do not appear adjustable, but the price is much lower than I recall the adjusble shocks selling for cost. OTOH, without the adjustment you can not match the dampening to the car's need, you can over dampen a wheel and it i will degrade the handling.
if you try them let us know how they work. though I am with teranfrbt, the KYBs are a good value with decent performance.
BTW, make sure all of your suspension bushings, tie-rod ends, ball joints, etc. are in good condition before you up grade the shocks. it will not do you any good to replace the shocks if there are other problems with the suspension. Also, have the alignment done, and up grade to 14" alloy wheels with lower profile tires, those will improve your handling more than the expensive shocks (presuming your current shocks are in good working order).
Re: Shock Absorbers
Post by ARCHINSTL » Mon Jul 09, 2018 7:42 pm
I used the KYB GR-2 Series back in 2010 and have been happy (also used its front strut inserts).
See viewtopic.php?f=3&t=5829&p=42970&hilit=shocks#p42970
Note that I replaced almost ALL of the bushings in the rear as well - see viewtopic.php?f=3&t=5830&p=42972&hilit= ... ngs#p42972
The Professor
Re: Shock Absorbers
Post by The Professor » Tue Jul 10, 2018 8:39 am
I happen to really like the over dampened feel of a suspension, it generally imparts a solid, unflappable feeling to the handling, though it can feel pretty stiff at times. Most German cars have a slightly over dampened suspension calibration, which is partly why they ALL feel so stable at high speeds.
1984 Subaru Turbo-Traction wagon
1984 Subaru Turbo-Traction coupe
1987 Subaru RX coupe
1987 Subaru RX Type-RA coupe
Re: Shock Absorbers
Post by Petros » Tue Jul 10, 2018 5:08 pm
there is a trade off on suspension stiffness. without variable stiffness suspension, you have to match the stiffness to the size and frequency of impacts. High speed cars will have a stiff suspension, but it will suffer a harsh ride at moderate speeds. A soft suspension gives a more comfortable ride at low speeds, but at high speeds it can feel unsteady since the tires do not stay in contact with the road surface as well.
I imagine BMW would want the reputation for high speed comfort and handling, even if they are made in the USA now, and made for the American consumer.
Some day it may be common to have suspension stiffness and dampening to adjust to road conditions and speed, right now, as far as I know, it is only available on high priced luxury cars and expensive sports cars.
I like simple, a lot less things to maintain and repair.
Re: Shock Absorbers
Post by ARCHINSTL » Tue Jul 10, 2018 6:34 pm
YESSS !
The Professor
Re: Shock Absorbers
Post by The Professor » Wed Jul 11, 2018 8:18 am
This is not necessarily true, as a digressively valved shock varies the amount of resistance based on shaft speed. Yes, it is usually more expensive than a linear valved shock, but it really is the most cost effective solution outside of active dampening shocks like GM's magnetorheological units.
Some reading: http://accutuneoffroad.com/articles/dig ... k-valving/
