Making Weber work?
mr_braaaap
My tercel:: 1985 bone stock
Making Weber work?
Post by mr_braaaap »
I was wondering how can I make this Weber 32/36 egv carb work is from a Jeep what else I’m I missing I got it for 50 dollars . I know I need the plate but what else would I need .
Re: Making Weber work?
an electric fuel pump with proper pressure or a regulator to reduce the pressure if you use 3a engine mechanical pump
base of carb to intake manifold adapter
there is a video on you tube showing how it was hooked up on a car i once had "toyota tercel 4wd weber" key words
