Hey all,
For those looking for one of these in the junkyards, I found one with my 4a engine from an 85' Chevrolet Nova. They are mounted in a hose that runs right above the flywheel end of the engine, appears to be identical component.
TVSV and drivability
Re: TVSV and drivability
Good looking out! Thanks!
- My tercel:: Two 1985 Tercel SR5 4WD, Cal. emission controls, one now a parts car (good engine & transmission, still had full power at 310K), another, a low-rust project car, with 307k miles, from Petros
Before I take a dive and reimburse xirdneh his $100 price for a new TVSV, I need to eliminate the possibility that a good used TVSV is available. I've just written Petros about his collection, but what about the rest of you guys?
It needs to be vacuum-leak-free and also to pass the tests on FSM page EC-22. The first one I found right here was vacuum-leak-free but it failed those tests.
After more study, it's become clear to me that the TVSV has to work right for cold-engine drivability. As page EC-54 shows, the auxiliary acceleration pump (AAP) is actuated by vacuum directly from the TVSV. No vacuum means no AAP actuation. But the sole raison d'etre for the AAP is cold-engine drivability.
i'm not the one selling the TVSVstanrob wrote: Fri Feb 02, 2018 9:54 pm Before I take a dive and reimburse xirdneh his $100 price for a new TVSV,
i have an all brass TVSV that i found somewhere. it has no plastic. the upper portion with the ports is all brass.
have not tested it yet. i am going to use it on the next tercel i work on that needs it
Oops, I should have remembered it was irowiki who had the brand new one.
While looking back at my meandering posts, I believe my choke actuation theory was insufficient to explain what's going on. More thinking, plus looking back at others' posts, persuades me that AAP non-actuation is probably the really important part. This is underscored by our colleague's reporting (far above) of a jerk encountered in the course of applying power when fully warmed up. His faulty TVSV was transmitting manifold vacuum to the AAP. This would be sort of a mirror view of my no-vacuum situation.
