Flat towing
Ellisdee
My tercel:: 1985 wagon
Flat towing
Post by Ellisdee »
I am planning on flat towing my tercel behind my motor home...any thoughts on this?
teranfirbt
Re: Flat towing
Post by teranfirbt »
Manual transmission is good to go, make sure it's not in 4WD.
Autos won't flat tow since they need the engine running to pump ATF and keep everything lubed.
Re: Flat towing
I have seen auto trans Tercels rigged to flat tow, there is a kit you can buy that has an electric motor that circulates lube while it is being towed. I presume it is 12 volts and runs off the tow vehicle power supply.
Manual trans is easy, just make sure the trans gear lube is topped up, and trans is in neutral and FWD.
