Wednesday night, after a mile or two, I noticed it was still sitting on "zero," and heat was beginning to emanate from the vents.
Now, I am paranoid about keeping a eye on the gauge, as that is how my Beloved Sister fried the head on my '83 in '85 when on an extended loan- she was accustomed to the idiot light in her poor Escort.
I stopped, popped the hood - checked all - everything seemed normal. I repeated that a few miles later at the grocery store.
Ditto when I got home - nothing was amiss. The upper hose was hot and the lower hose was cold and coolant levels were as normal.
Today, I checked the sensor and while its blade did not look oxidized/corroded, I simply rubbed it with my fingers - I also very slightly bent the "tab" on the "plug." It was still kinda loosey on the blade, but I did not want to chance bending it more. I let the engine run for 5-6 minutes and the needle moved. OK?
Tonight I took it on a run to the Post Office, and the gauge worked per normal. I again popped the hood and all was OK on coolant levels and again the upper hose was hot and the lower hose was ice cold. And again, no funny noises.
Has anyone else experienced this? I did a search last night and found no similar reports.
Thanks,
