How to Replace a Head Gasket: Petros method
snephi11
My tercel:: 1986 Tercel SR5 manual(duh)
Re: How to Replace a Head Gasket: Petros method
Post by snephi11 » Thu Jan 08, 2015 7:13 pm
All hail Petros! Wow, this is amazing! Thank you!
entrax
My tercel:: 1987 Tercel SR5 4wd
Post by entrax » Fri Jan 16, 2015 2:10 am
just one thing i couldn't find, i'm in the process of cleaning off gasket material. you mentioned wire wheel for the block, how about the head? i've heard of using a brass wire wheel? thoughts?
My Toys
______________________________
The Cruiser - 91 MR2 Turbo
The Girlfriend's - 86 MR2
The Winter Beast - 87 T4wd SR5
vcp
My tercel:: 1987 Tercel 4WD wagon
Post by vcp » Sat Mar 28, 2015 11:19 am
Hey Petros, thanks for this guide! Gonna give it to my mechanic before we do mine.
dglassplus
My tercel:: 1984
Post by dglassplus » Tue Jun 16, 2015 1:15 pm
My cam shaft is blocking the head bolts. I'm very confused.
dglassplus
My tercel:: 1984
Post by dglassplus » Tue Jun 16, 2015 1:23 pm
larry mcgrath
Post by larry mcgrath » Tue Jun 16, 2015 1:41 pm
You need to pull the cam, to get clearence to the head bolts. larry
dglassplus
My tercel:: 1984
Post by dglassplus » Tue Jun 16, 2015 1:45 pm
Thanks Larry, that's what we were leaning toward. Just wasn't in the procedure, wanted to make sure we wouldn't cause damage. Not a mechanic.
Post by irowiki » Tue Jun 16, 2015 2:01 pm
I have done it without removing the cam, but it can be tricky. There's a flat part of the cam there that allows sticking a socket in there.
81 Coachmen RV, 70k miles
95 Camry Wagon, 153k miles
04 Camry Sedan, 250k miles
dglassplus
My tercel:: 1984
Post by dglassplus » Tue Jun 16, 2015 2:06 pm
Hmmm...we tinkered for a bit I couldn't manage to get them going.
dglassplus
My tercel:: 1984
Post by dglassplus » Tue Jun 16, 2015 2:22 pm
The bolts have a flange under the head of the bolt that doesn't clear the cam shaft on the driver side. No flats on the cam shaft. Is this somehow not stock?
Gottolovem
Post by Gottolovem » Tue Jun 16, 2015 2:49 pm
Keep trying I've never needed to pull the cam
Post by irowiki » Tue Jun 16, 2015 2:59 pm
In that picture you posted you can see the "flat part" just to the left of the center of the camshaft.
dglassplus
My tercel:: 1984
Post by dglassplus » Tue Jun 16, 2015 3:14 pm
Post by irowiki » Tue Jun 16, 2015 3:23 pm
Woah, something going on with #2 there...
dglassplus
My tercel:: 1984
Post by dglassplus » Tue Jun 16, 2015 3:54 pm
Yeah. Some pitting on the head; and the rust in the cylinder might have killed it.
