Need Real-time Help. Car won't start.
battmrown
Post by battmrown » Wed Mar 27, 2019 10:32 am
First post here, so hi everyone. My name is Matt. 84 SR5 Wagon. I was changing the oil today and the filter was stuck like hell. I grabbed my filter wrench and while undoing it, touched the alternator at the connection I'm pointing at in the attached photo. There was a small spark and now the car won't start. It doesn't even buzz when I put the key in. No flow of electricity whatsoever. I'm hoping I haven't fried it completely but electrical Gremlins are not my strong suit. Battery is fine. Grounds seem well-connected. Any advice would be much appreciated.
battmrown
Re: Need Real-time Help. Car won't start.
Post by battmrown » Wed Mar 27, 2019 10:34 am
Having trouble attaching the photo on mobile. It's the right side connection if you're looking at the alternator from the front. Battery side.
BaileySims
Post by BaileySims » Wed Mar 27, 2019 10:41 am
From the fuse box under the hood goes a single wire to the positive on the battery. That might have been disconnected, or one of the fuses could have blown?
WAGON MAFIA.
Blood, sweat and beers.
battmrown
Post by battmrown » Wed Mar 27, 2019 11:21 am
YEAH! Just looked at the fuses and the big 60A one is blown. Gonna swap it out and hope that takes care of it. Thanks for the quick reply!
battmrown
Post by battmrown » Wed Mar 27, 2019 5:04 pm
Shut 'er down, boys. Problem solved. Probably should have just consulted Google instead of clogging up the board. Thanks for your help, @BaileySims.
Post by Petros » Wed Mar 27, 2019 6:11 pm
welcome to the forum, looks like you found the problem.
that big 60a fuse is a system main fuse designed to blow to protect the rest of the electrical. I had that happen once when my old brittle wire harness grounded out and left me stranded. I wrapped the melted wires with electrical tape, and a guy driving a rusty old beater chevy stopped and gave me a foil gum wrapper to put on the 60A fuse to get it to run. Power it up and it got me home.
