Temp gauge reads very low with hot engine
- My tercel:: 1985 Toyota Tercel 4wd Sr5, Fed emission but no cat converter. Manual transmission, with air conditioning.
After removing my carb to try to rebuild it, I notice my temp gauge reads very low, like barely above cold, but my cooling fan kicks on. What is going on here? I don't want to overheat my engine!
Re: Temp gauge reads very low with hot engine
Is the wire for the temp gauge connected? It clips onto the little metal tab at the front of the engine, near the TVSV.
Yes, the wire is connected, and the connection is clean. I'm wondering if the sensor itself is the issue. My coolant is clean and fairly dark green, maybe I need to drain some off and add distilled water to the system.
Yeah, my guess would be the sensor or the gauge. I can't remember if the FSM has a test procedure for the sensor, like how many ohms it should be at certain temps. I would look into that first.
