Camry struts??
Camry struts??
I heard Camry struts in the front will give you 2-3” of lift, is this true and if so what year Camry struts??
1985 4wd sr5 wagon
1981 3door hatch
1981 3door hatch
Re: Camry struts??
I know everyone hates being told "do a search" but there are countless threads on this topic. Just search "Camry strut"
But also, keep in mind that if you do a lift without lowering the transmission, you are going to wreck CV axles fast. A few members here have documented how they lowered the other stuff to prevent that. I think it was Professor who detailed it best.
Re: Camry struts??
I do not recall anyone using the camry struts, but some have used the springs from the camry. the lower end of the strut mount is different, uses larger dia bolts. the camry spring is actually softer than the stock spring, more of a "luxury" ride. but they are longer so they raise the car.
there is a larger dia strut assembly that has a similar length and stoke that came in the corrolla All-track, that will work well in the TErcel4wd if you swap out the upper mount. it gives about an inch of extra ride height as I recall, stiffer spring and larger dia strut tube (stock Tercel is 1.5" and the All-track strut is 2" dIa). the All-track is a heavier car so the spring is more stiff. It might be the same strut used in the Camry, but I do not think so. it would be good if it was, the All-trac corolla is hard to find in the wrecking yards.
Re: Camry struts??
No worries did a little more digging and found the thread..dlb wrote: ↑Fri Feb 25, 2022 9:46 am I know everyone hates being told "do a search" but there are countless threads on this topic. Just search "Camry strut"
Think I’m gonna just keep it stock for now..
1985 4wd sr5 wagon
1981 3door hatch
1981 3door hatch
