https://www.ebay.com/itm/254604060965
It's a pretty solid deal for a pair and I need to replace one of mine.
Do these look correct? I know there's a diameter issue with some of the cheaper/rebuilt CVs.
Is this the correct cvs?
Re: Is this the correct cvs?
Hey Neu,
Yes, these appear to be the correct Trakmotive axles. Rock Auto has them for $51/each plus shipping, I would imagine it would work out pretty similar.
listing shows they are the correct axles for the T4wd. the issue with spline fit/binding is a manufacturing error, I think from one brand, and there is no way to tell if these suffer that problem, but it is actually rare, so they should be good for your car.
- Neu
Thanks! Looks like they're $110 from rock auto so I'll go there.
- My tercel:: 3 wagons now
I bought a pair from rock auto they bound up trying to put them in. After a few minutes of comparing to the old ones I realized the retaining ring on the new ones was larger. Put the ring from the old one on the new one & no more binding. Look that over when you get the new ones.
- Neu
Thanks that's nice info, atoyta.
I'll probably wind up replacing the seals, too. Does anyone know the socket size to get em in? Or any tricks/tips.
In case anyone comes across this, this thread had more info on the seal viewtopic.php?f=16&t=6484 . Toyota part number is 9031132006
There is a drawing showing dims to build an installer from plumbing parts, works well.
- Neu
There isn't a socket that'll fit? That's what i've done in the past is just found a similar sized socket and tapped it in using that.
- BaileySims
I believe the seals have to be installed at a particular depth, otherwise it will still leak.
viewtopic.php?f=10&t=13310&p=109719&hil ... ol#p109719
WAGON MAFIA.
Blood, sweat and beers.
