So, been wondering why my mothers tercel has been going through tranny fluid so fast since the install.
When I had it on my lift topping off the fluid, I noticed where the main source of the leak was from-the rear output shaft.
I noticed the driveline was a little "back" so I undid the carrier and pushed it father in hoping to help fix the leak.
Wondering if the seal (if there is one) behind it is easy to fix and what I need to do.
1984 4WD SR5
Transmission Leak
Re: Transmission Leak
transmission rear seal is fairly easy replacment. Do it ASAP or you risk trashing the transmission. New seals are available from most autoparts stores, it is a standard part made by several seal manufacturers, they do not cost much. Or order one from rockauto, but that takes while for it to arrive.
You remove the drive shaft by unbolting it from the rear diff/and remove the carrier bearing retainer, than pull it straight back. there is a metal collar or sleeve around the rear tail shaft output flange to protect the rear seal, it just slips off, and it exposes the old seal. pull it out with a screw driver or seal tool, clean the seat and carefully slide in the new one. I put non-hardening form-a-gasket in the seat to make sure the seal stays put, but it is not necessary, just make sure the seat is clean. I also put some gear oil on the new seal lip so you do not damage it when you slide in the drive shaft.
BTW, the rear spline sleeve on the front end of the drive shaft is not supposed to be pushed all the way forward, it has to move fore and aft to accommodate the slight change in length from arch of the the rear axle as is swings up and down.
Sounds like cake.
The collar/sleeve just comes off? No clips or anything?
yes, it is a slip fit, not even pressed on. As I recall, I thought it was going to be difficult to get it off, but I think I tapped with a soft hammer back and forth and I pulled it off the rest of the way by hand.
