Always diagnose the problem before you fix it...
- BaileySims
Famous last words to live by. Should have remembered this before pulling the transmission in my wife's suv. Oil appeared to be leaking from between the trans and motor. Turns out the damn oil filter is behind the engine sitting above the transmission that has been leaking the whole damn time. 20 minute job turned into a 20 hour job. I will live by this phrase forever now. Thanks petros.
WAGON MAFIA.
Blood, sweat and beers.
Re: Always diagnose the problem before you fix it...
my favorite saying to newbie do-it-yourselfers. yup, I learned that one the hard way too.
oil leaks are especially easy to assume you know where it is coming from, there are a few obvious places (seals, o-rings, etc) where it comes from, and a lot of other non-obvious places that leaks all over and fools you on where it is coming from. been through that scenario more than a few times too.
- CathodeRayTube
- My tercel:: 1985 4x4 Automatic - restored
I changed my oil stoned once and dumped about 3 quarts of new synthetic oil out on the ground with the drain plug missing...
85 T4 DX 4x4 Automatic
83 T4 SR5 - junker/parts
94 4Runner V6
86 Mercury Grand Marquis
88 Lincoln Town Car
90 Yugo GV+
94 4Runner V6
88 Lincoln Town Car
90 Yugo GV+
CathodeRayTube wrote: ↑Mon Sep 11, 2017 10:29 pm I changed my oil stoned once and dumped about 3 quarts of new synthetic oil out on the ground with the drain plug missing...
Not as bad as the guy on here somewhere who decided to do an oil change and a coolant flush at the same time while drunk and swapped the fill.
95 Camry Wagon, 170k
97 4runner, 275k
97 4runner, 275k
I once put a set of rings in an engine upside down (markings were not clear, and little instructions booklet showed 12 different type of ring styles!).
Engine ran good but pumped oil out the exhaust like a hydraulic pump. I got to rebuild it over again. made sure rings were in correctly this time!
