HAI Hose
tabercro
My tercel:: 1985 SR5 4WD
HAI Hose
Post by tabercro »
Hi All,
I posted a couple of days ago with questions pertaining to my 1985 having major idling issues. The more I dig into what's going on with my carburetor and fuel system, the more little issues I find. Old and cracked hoses (vacuum, PCV, etc.). At this point, I'm starting to wonder if my setup has been tweaked over time to compensate for issues as they came up rather than actually fixing them. Yesterday, when I removed the air filter assembly, I discovered that there is no HAI hose attached. Here are my basic questions:
1. What does HAI stand for? And what does it do, specifically?
2. Is there a guide somewhere that deals with all of the acronyms that are often not spelled out? People referred me to the AAP being a possible issue and it took some digging to figure out that one. There are lots more in the FSM, not all explained when you want them to be!
Thanks in advance for any help.
-Tom
1985 Tercel SR5 4WD
1992 Volvo 740
1999 Volvo V70 R AWD
1986 Vixen 21TD
Re: HAI Hose
HAI = Hot Air Intake
http://tercel4wd.com/fsm/1985T4WD.pdf
page EC-43
Re: HAI Hose
Make sure the three ports at vac adv are hooked up correctly. The HIC port has a pinhole. Usually its on top passenger side but i have seen it on top drivers side once
