door panel clip?
Erikwi
My tercel:: 1988 stock auto
door panel clip?
Post by Erikwi »
i found the male ones, im missing some female ones too!
what are they?
Erikwi
Re: door panel clip?
Post by Erikwi »
update
my dealers parts dept could not find the part number?
im sure it exists but we do not know it.
are you talking about the little plastic things that secure the door panel? Like when you remove it, you tug hard and they pop out? Like these:
https://www.ebay.com/itm/15-Toyota-Fron ... 0253436111
It's hard to tell but they might be part # 67601A according to this diagram:
Just do an image search for "1986 tercel door panel parts" or something like that and you should be able to find other diagrams that show the clip you seek more clearly.
Erikwi
Post by Erikwi »
The ones that fit into the steel door frame. The female end
many auto parts stores have racks of miscellaneous plastic fasteners and fittings. often you can find one that is almost identical among those fasteners. take one from your car into the parts store to see if you can match it.
and you likely can find it on Amazon if you can describe it correctly.
Erikwi
Post by Erikwi »
the other side is missing them too.
i did look on ebay but without a part number i did not find any
BaileySims
Post by BaileySims »
I ruined all of the female type ones in the door for the rub strips. I ended up using small circular black rubber gromets from harbor freight. I don't think you'll be able to find any of those oem ones.
WAGON MAFIA.
Blood, sweat and beers.
Petros wrote: Thu Jun 11, 2020 11:14 pm many auto parts stores have racks of miscellaneous plastic fasteners and fittings. often you can find one that is almost identical among those fasteners. take one from your car into the parts store to see if you can match it.
+1. I've seen copies of the various fasteners at my local parts store.
Erikwi
Post by Erikwi »
i want to apologize
i did not find out until HOURS of searching. literally.
that they came TOGETHER.
they are the same part number.
so for you people, thats the part number and its not obsolete.
there are also copies of it on amazon, in various colors.
Thanks Erik, great info.
The Professor
Post by The Professor »
My Subarus use an identical clip on the door panels, these are pretty universal.
