Switched Turn signals to LED . Hyper Flash
Buzzard67
My tercel:: 1984 Toyota Tercel Delux
Post by Buzzard67 »
Switched turn signals to Amber LED Bulbs, now have hyper flash.
I heard you can change out the flash relay to fix the problem.
Okay, where is the flash relay located at on 1984 Toyota Tercel 4WD DXL?
Or is there another solution?
Let me known.
Thanks
Buzzard67
Re: Switched Turn signals to LED . Hyper Flash
there was a thread on this in the archives.
As I recall, the solution is to add a simple resistor to the circuit to approximate the total resistance of the stock bulb.
Post by splatterdog »
Finding working flashers is easy, follow the clicking. Using a resistor only defeats the amp draw reduction of leds.
helipilot77
My tercel:: 1984 SR5 wagon
Post by helipilot77 »
I did this mod on my last Tercel. The flasher is buried behind the steering column kind of by the age cluster. If I remember correctly it was a three pin flasher that I bought off superbrightleds.com
. / TOYOTA
./_| |/|/ |]
SirFoxx
Post by SirFoxx »
Is there a relay thats plug n play with the toyota harness? I know they are three pin, but on my '81 the pins are much closer together than a standard 3 pin relay is.
1985 4wd Tercel SR5 (RIP)
