can anyone tell me what engine this is?
<a href='http://cgi.ebay.com/ebaymotors/New-1-6L ... 5701QQrdZ1' target='_blank'>ebay link</a>
and if its a 4afe can my new rebuilt 3ac head fit on it and can it fit in the tercel with no mods???
im searching the site for the answer, but there is like 2 hours left.
what engine
That is definitely an 88-89 Toyota 4AFE bottom end. I recognize the block as being an 87+ 4a block (7 ribs). The crank has 6 bolts for the flywheel which means it is a 4afe. The 4ages had a 8 bolt crank.
Anyhow, either way that is a smokin good deal.
Your 3ac head WILL bolt onto this block. Your 3ac flywheel WILL bolt onto this crank. This block WILL bolt up to the tercel bell housing.
However, I'm not sure about the 3AC engine mounts, and not sure what you would use for an oil pan (what will fit both the block and into the tercel). I'm about 95% sure that it'll work just fine though.
You MAY have interference problems between your 3AC valves and the 4AFE pistons. They may not touch normally, but if your timing belt went, I'm pretty certain they would interfere. The fly cuts in the 4AFE pistons are for a 16V head, not an 8V head.
Also, I'm not 100% sure about matching the 3AC waterpump and oilpump to that block. I believe they are bolt on, but again, not totally sure.
For that price, it's probably worth a try.
Good luck!
Good luck!
Current:
91 LJ78 Landcruiser EX5
95 A32 Maxima SE
Former:
87 AW11 MR2 Smallport 4AGZE
93 Taurus SHO ATX
86 AL25 SR5 6spd 4wd
90 AE92 GTS
82 KP61 SR5
85 MX73
87 AE86 GTS 4AGZE
85 AE86 GTS
83 AL21
95 A32 Maxima SE
Former:
93 Taurus SHO ATX
90 AE92 GTS
82 KP61 SR5
85 MX73
87 AE86 GTS 4AGZE
85 AE86 GTS
83 AL21
Actually there was for sure a 4age in the Geo Prizm GSI. The 88-89 had the large port TVIS 4age, and the 90-92 had the small port high comp 4age. The non GSI models had the 4afe.shogun wrote: i have to agree with you man its a 4afe, being that there to my knowing there was no 4age in the geo prizms
Current:
95 A32 Maxima SE
Former:
93 Taurus SHO ATX
90 AE92 GTS
82 KP61 SR5
85 MX73
87 AE86 GTS 4AGZE
85 AE86 GTS
83 AL21
95 A32 Maxima SE
Former:
93 Taurus SHO ATX
90 AE92 GTS
82 KP61 SR5
85 MX73
87 AE86 GTS 4AGZE
85 AE86 GTS
83 AL21
Probably the same one, as the first never sold.Thereminator wrote: That seller has another Block with five days left...Buy-it price $279.00
Current:
95 A32 Maxima SE
Former:
93 Taurus SHO ATX
90 AE92 GTS
82 KP61 SR5
85 MX73
87 AE86 GTS 4AGZE
85 AE86 GTS
83 AL21
95 A32 Maxima SE
Former:
93 Taurus SHO ATX
90 AE92 GTS
82 KP61 SR5
85 MX73
87 AE86 GTS 4AGZE
85 AE86 GTS
83 AL21
