He since put 10,000+ miles on the setup.JB3 wrote:6- Modify the input shafts (if you decide on this route) In order to do this, you will need to measure the length of the 240 shaft over the 190 and make sure that this is maintained during the swap. You will need to cut the end off of the 240 and weld it onto the 190. Both shafts are hardened on the outside only. A comparison shot-
notice the general large difference between the two. I chose to make my length measurements off the end of the taper on the bearing side of the shafts-
After cutting the shafts-
The machine shop cut the shafts, drilled down the center point and threaded the 190 bearing side and the 240 spline side. pic-
I had the shaft checked for balanced after cutting, and a 45 cut into it for better weld penetration.
before and after welding-
7- Check the input shaft for true. After the welding its worth taking it back and having it cut down and rechecked for true and balance by the machinist. Again, there is no better time than while you have it apart.
Could this be done with VW and T4 input shafts? It seems like a good solution, as it would allow use of the VW clutch with the T4 tranny. Even if you had to build an adapter plate and custom motor mount arms, I don't think life would get too terribly difficult -- and then you'd have a diesel for which you can readily find parts in the US, which I think would more than save money in the end. The VW NA 1.6 diesel makes ~55 HP and ~75 lb ft of torque, so I don't think one would have to worry about ripping the input shaft up.
I recently became aware of a summer-winter swap program in MA where you can swap registration between different vehicles for $25 per swap (with the idea being that someone with, say, a sports car and a Jeep could drive the cars with one registration, using the appropriate car for the appropriate season. Since this would make adding a third car to my fleet quite affordable, I was thinking of buying a T4 and trying this out. What do you guys think?
