Do you think this would fit our tercs? http://www.ebay.com/itm/wood-steering-w ... 1131912871
Thanks,
Jesse
Would this steering wheel fit?
Re: Would this steering wheel fit?
it should probably fit but to be sure, just remove your steering wheel and measure the inner diameter of the hole and then ask the seller to take the same measurement on his steering wheel.
to remove your steering wheel, undo the two phillips screws from the back side of the wheel and pull the center pad off. lock the steering and undo the 17 or 19 mm (can't remember which) nut. mark the position of the steering wheel against the steering column trim so you can put the wheel back on in the correct position. yank on the steering wheel a bunch, rocking it from side to side, but be careful not to break your nose when it finally gives. installation is the same steps reversed.
Interesting find. all the way from Thailand, did you notice the shipping is $80, plus the $80 sale price?
I would suspect it would fit, but I do not know the year. Similar model years should fit, but that could be much older.
Not sure that much money for a used steering wheel is worth it, the center looks worn and sun damaged. New custom ones are about that much, give or take. Or you can get a "wood look" cover for about $40.
