4a head on 3a block wich head gasket?
nugtown
My tercel:: 84 sr5 4wd tercel w/ sunroof 89 alltrac
Post by nugtown »
Hey guys new to the forum, 85 Tercel 4wd. Raleigh NC. have a cracked head and replacing with a head from a 4a on to the 3a block, which head gasket should I buy? the gasket part numbers were different for each.
Re: 4a head on 3a block wich head gasket?
Welcome to the list!
I would go with the 4a head gasket, everything else should align okay. I thought the aftermarket head gaskets were the same, but I never compared them. I suggest doing the mods and follow the procedure for my head gasket installation over in the repair guides section. Here: https://tercel4wd.com/forums/viewtopic.php?f=7&t=6059
How did you crack the head on your Toyota? I have really badly abused and overheated my 3a head a number of times, but I never cracked it. I did warp it badly, but it was still able to be resurfaced and the cam bore had to be redone to align it.
that's odd because according to this guy from the 4ac-powered forum, the 3a and 4a heads are the same except for the valve cover so the head gasket should be the same. check out his post.
https://tercel4wd.com/forums/viewtopic.php? ... 225#p53914
if the part #s are different, they must be different though. pretty weird.
