stutters like it will choke off
Have the dist thoroughly tested. My dist problems caused massive hesitation (and random dying)
Turned out I had a few issues;
Bad coil
No Mechanical Advance
Glitchty vacuum advance
A bad lead wire
Bad coil
A bad lead wire
Try plugging the vac line at the EGR to see if this stops it...if it does, then something controlling the EGR is a fault (vac modulator?)...or the EGR.
