free 87t4wd, you haul, minneapolis mn
tercellenthusiast
Post by tercellenthusiast »
Hey guys i have an 87 t4wd sitting in someones yard that i finally need to give up on, if you can come and haul it away, its yours for free.
The bad:
Been sitting for 5 years, SHOULD run, but havent tried
Needs clutch, this is why it was parked, clutch is completely shot, not just slipping, will not move under its own power
Lots of rust, but was road worthy when parked
Frozen in place, wheels will not move, tried to pull it out with a truck
In an aquard to get to side yard, could back a flatbed tow up to it, but it would be hard to pull out with a truck
Broken dvr window but has a plexi window, comes with replacement window
Baled tires come with it, but they hold air fine
The good:
Transmission is in good running shape, 6 spd
Lots of recent work b4 it was parked, shocks, wheel bearings, fixed gas filler pipe, all new hard and flex brake lines
Clean title
Let me know if you think you are able to come get it in a reasonable amount of time (once it snows it will be verry difficult to get to), i will help as much as i can
Re: free 87t4wd, you haul, minneapolis mn
someone call emmahumpfritter or splatterdog! sounds like a good project.
splatterdog
Post by splatterdog »
YES PLEASE!!!
tercellenthusiast
Ok look like its spoken for by splatter, thanks guys
