charging problems
My 84 is externally regulated.
I cannot answer your question, rather, I can add one.
How, if possible, can I set in a single-wire (or otherwise high-powered) alternator in the Terc, once I get the problems figured out?
I have a schematic, but no way to post it...having gone thru a charging problem...I can say that the wiring is a lot different for the int vs ext regulator setups.
I spent a week or so "diagnosing" the charging system and found that the new regulator was defective....in this case the alt was charging way too much and getting hot.
My first Tercel wagon was a freebie that the owner had abandoned in an airport parking lot (hourly parking for 3 months) after the car quit charging. I had the alternator tested, and replaced the regulator, but the problem remained. 15 minutes at the auto electric shop discovered a bad relay under the hood, so you might try swapping the relays around to see if it makes a difference.
well,replaced some wires and now it's charging.charging around 15 volts but its better than nothing.i guess i'll adjust the regulator. Typrus,i don't see why you couldn't change to a one wire.we used to do them to old toyota trucks to bypass the charge light relay.getting one to fit without bracket mods or fabrication might be an issue.
there is only one jeep.and that is one too many!
Bentley schematic for the '84..ext reg....
* shows (4) wires...
- White
- W-Light Blue
- W-Green
- W-Black
last 3 go to the regulator...new one I bought was electronic...not too much to adjust...
apparently they also used the int reg type...cause they also show a shematic for it.....
- White
- W-Light Blue
- W-Green
- W-Black
