I bought this car a little over a year ago for $1700, it ran great and I knew it was gonna take some work to fix it up nicely. However, I took it on a long road trip and blew the head gasket. Since then I have replaced the head gasket, water pump, timing belt, radiator, ignition coil, tires, steam cleaned the seats and carpet inside.
What I know it needs done is cylinder/piston work, the shocks are leaking so maybe new shocks or just the seals, carburetor could use a deep cleaning, some minor leaks around the engine, passenger side back corner has a dent (came with the car) and a new paint job should do the trick.
I don't necessarily have the time and patience to keep working on the car to get it back to "normal" good running shape and I think I would rather just go without a car for a while.
I am in Bellingham Washington if anyone is interested in rebuilding it for personal use or to resell, I'm willing to work out a deal.
My email is sydneystanley@gmail.com or you can give me a call at 360-927-3713 if you have questions or inquiries.
Thanks!
1985 Toyota Tercel 4wd $1000
- My tercel:: 1985 Toyota Tercel 4wd
1985 Toyota Tercel SR5 4wd - name is Otis
2010 Kona Dew - Roadbike named Blackie
2005 Honda Metropolitan- named Dreamsicle
