SUCCESS!!!
Ok, this is what I did, to get that depression out from the bottom of the pan where that channel is in the thread bore is. I cut the head of a bolt with a Demel in such a way that it was able to fit into the channel of the threads.Then the bolt was threaded into a short slide hammer with which I bumped out the divot. Used the OEM gasket torqued the drain plug to 25 ft.lbs. and its bone dry Yes!
Oil drain plug gasket
- splatterdog
Re: Oil drain plug gasket
Nicely done! Must not have been too bad. My 84's plug had been overtorqued so bad I needed a whole new sealing surface. Amazingly tough pan threads, that's for sure.
- MrWrench
Reviving a really old post. I am hopefully going to try and repair mine as well. My 84 is constantly leaking oil and I cannot get it to stop! No matter how many different gaskets/seals I try.
I used some oil dye to verify that it is for sure leaking from my drain plug.
I don't remember this thread but I'm glad you brought it up, MrW. I have an 83 and the drain plug currently does not leak but if it does, I'm glad to have some ideas on how to repair it.
Just smear some RTV gasket maker around the sealing surface before installing the drain plug!
- SirFoxx
rtv doesnt stick to oily surfaces.
1985 4wd Tercel SR5 (RIP)
i clean the drain plug, smear the RTV on it, and install it in the oil pan- has worked for me!
I attached a picture. Look at right side centered between two spot welds. That is a divot. Under divot is a square notch in the threads to allow every last drop of oil to drain. If you look closly you can make out the square hole. If sheetmetal gets bumped there it will deform the metal and no matter what you do with plug it will leak. i ground a piece of steel rod to a square shape to fit in square hole and pry sheetmetal up.I
Also there are hydraulic line washers that work well too. I forget what they are called but they are steel washers with rubber built in around the hole in the washer.
Dowty washers
Dowty washers
