Help needed!!
Help needed!!
Hi - I've got an 87 tercel with a buggered engine. The heads gone bad and was only running on 3 cylinders. I've found a corolla 4A-F factory long-block and I'm wondering if this would be a bolt in install or a major challenge. Help needed as I'm new to all this. Opinions? Unfortunately, the other tercels I have are barely any better and the wreckers where I live are a joke. I'm a single father with no time, so I'm hiring the work done. Would this engine work? It looks like the exhaust is on the other side and the distributor is at the back causing firewall problems...
What do you think?
What do you think?
Re: Help needed!!
4af is completly different from the 3ac fitted in our cars (i assume your engine is installed longitudnally rather than transverse.) if so, a 4ac from a corolla or chev. nova is pretty much a bolt- in affair. just have to swap intakes and accessory brackets (should be plenty of threads here with particulars.) if the head's the only problem, why not just fix it?? lots less work than swapping engines! hope this helps.
Re: Help needed!!
Looks like the dizzy is gonna be in the way and that something you can't move around!
Labine R.
Labine R.
- My tercel:: None
Re: Help needed!!
This engine swap has been done before, but it requires quite a bit of work. Since it was designed for a FWD application and has a cross-flow head, you would have to reroute the radiator hoses and have to have a custom exhaust header fabricated to clear the steering column. In addition, you would have to hammer in the firewall or switch to a distributor-less setup. It will end up costing you a lot more than just finding a good remanufactured cylinder head if the engine block in your car is still in good shape. However, the perk would be that you would have about 90 HP or so with the carbureted setup.
2015 Honda Fit EX "Malachi"
Re: Help needed!!
how has the "head gone bad"? if it's just a valve that's no biggie, and even if the head is warped you can get a good one from a wrecker and throw it on pretty easily. not a big deal, and far easier and cheaper than any engine swap.
Re: Help needed!!
Thanks for your replies and your wisdom. I have a line on another used engine that was running previously but has sat for a while. That's likely my best bet now. I was given an estimate of $1400 to rebuild the head and reassemble everything. That kinda scared me. Again, I simply don't have the time to work on a project now, so I'm stuck paying to have it done. Thanks for the advice!
- My tercel:: '86 SR5 6 speed
Re: Help needed!!
So how do you know the head needs to be rebuilt? If so, $1400 is a bit pricey, you might want to get a few more estimates/diagnosese.
Re: Help needed!!
pulling a head to replace the head gasket is relatively easy. At most I have just had to replace exhaust valves, stem seals, hand resurface the gasket face of the head and put in a new head gasket. Tpically a 4-5 hour job, and if you have everthing ready it can be done in a saturday. I have done between getting home in the evening, and getting to bed with a new headgasket in a running car before midnight. Way cheaper than replacing the engine.
Unless the engine is completely shot (thrown rod or broken pistons), it is always cheaper and easier to just fix the head. The shop estimates assumes they have to replace everything, so they are charging you retail for all new parts. My experience is that is very rare, particularly if you have a running engine now. Most likely it just needs a head gasket (about $20), and a 3 hour head gasket replacement.
See my thread in the repair guides section on "head gasket replacement: Petros method".
Re: Help needed!!
I suspect I'd have to do all that Petros - The trouble is, I have no time. I'm either juggling my two kids (4 and 2) or else working. Plus it's not easy without a garage in central Canada in early February. I have a line a running engine for decent price. I could at least swap the head...
Re: Help needed!!
It is far easier and less time consuming to replace the head gasket than to swap an engine. If you have no time for swapping a head, than you certainly have no time to swap an engine. I have worked outdoors in all kinds of weather, including subfreezing (far easier in warm weather!). Perhaps you can build a tent out of heavy traps and a few 2x4 lumber, bring out extension cords and use lots of lamps (I like using heat lamps in winter for both light and warmth).
Re: Help needed!!
That diagnosis sound a lot like, "I don't wanna do that job, but if he threatens me with money..."
Most shops do not appreciate (significantly) older cars arriving for repairs, they instantly envision seized bolts and owners without money.
How much time did they spend diagnosing it?
Are you sure that is the required repair at this time?
A few years ago, I had a "3 cylinder event" while on a road trip with my then 2 yr old and no tools, middle of February.
Stopped by a reliable shop and was told the engine was toast, ended up limping back home (500km).
Was already to start pulling the head but checked the plugs first, #2 was a nobody home affair (we're talking totally melted), replaced the plugs and it ran decent.
That was over 100K ago and I still haven't opened the engine yet.
Not sure where central canada is?(depends on who you ask) but where I am (snow belt, just north of the centre of the universe) we have had a miserable winter, no freakin snow and hardly any ice, been murder on the ice fishing season but has made the driveway repairs much more tolerable, for which I am very thankful.
Being that I am also doing the single dad impersonation, I have some empathy for your plight, but spring is just around the corner.
Hang in there and do a little digging around, you may be able to squeak by until the weather improves enough to action it properly.
-Jarf
-Jarf
Re: Help needed!!
Hi Jarf - thanks for the reply and encouragement. I think you're right on the money with the "I don't wanna do that job, but if he threatens me with money..." That's pretty accurate. Even though the wreckers around Winnipeg are a joke, I was able to find a complete engine for a decent price. It's apparently a good runner that has been sitting for some time, so we'll see how it is...The shop was sure the head needed a full rebuild and he was also worried about the rings being broken with possible cylinder damage on one cylinder. I decided for the price, I'd roll the dice and do the swap. Wish me luck, I'll see how this goes over the next week or so.
Cheers.
Cheers.
Re: Help needed!!
mytercel, how did this all pan out in the end?
