A/C Factory kit
tompat011
Post by tompat011 »
I picked up an A/C retro kit for an 87 4wd Wgn ....I have an 86. There seems to be at least a few differences that I'm wondering about...the Compressor to engine bracket seems to be different as well as the pulleys....I believe the newer takes a serpentine belt....I'm hoping that the compressor pully can be changed and I'm hoping that a proper bracket for an 86 will work.. Is there Anybody in the know that could shed some light on this, Please....ie is this do-able?
Appreciably,
TJ
PS I'm contemplating picking up an 89 corolla all-trac....Is there a Forum for these somewhere? The car is almost identical in most areas to the Terc....But I haven't been able to come up with much info on these so I could be way off here.
Post by Chris »
I put an A/C kit in my 86 about 3 years after I bought the car new. It was for an 87-88. I had to buy a bracket that the compressor and alternator could mount to. The compressor drive belt tensioner also mounts to the bracket. I would try to get the bracket at a wrecking yard. A longer alternator drive belt will be needed since the alternator is set a little further away from the engine. The pulleys won't have to be changed. It is very do-able....if you have a little understanding of refridgeration systems.
I have a set of illustrated instructions to make the job a lot easier. Let me know if you need a copy. If you need any other info...don't hesitate to ask. E-mail me if you want.
tompat011
Post by tompat011 »
Chris,
I just wanted to thank you for the info. I did respond to your email and I appreciate the help.
TJ
Tercel4wdQuébec
Post by Tercel4wdQuébec »
Well,
i did remove a complete A/C OEM kit from an '85 SR5 and installed it on my '87. Everything was A1. I did have to change the alternator bracket and the bracket for the compressor. Mine is a 10P13A Nippodenso (Compressor).
Believe it or not, on Canadian models, the wiring for the AC was not installed at the factory. The A/C kit came with a complete wiring for aftersale install. It was a BIG job to install it. But since it works for 2 years now, i'm glad!
Chris, do you have a PDF version of the installation instructions, I would really appreciate to get it
thanks
Vince
Montréal, Québec, Canada<br><br>Tercel 4WD Wagon DLX 1987, 383 000 KM, Original Engine, Light Silver, Black Deluxe interior, 6-spd, Owner since 1998, repainted perfectly in 2001, Installed Factory A/C removed from a 85, SR5 3-spoke steering wheel, SR5 tach. cluster, SR5 intermittent wipers, Anti-theft system, Kenwood CD Player, Pioneer Speakers<br><br>Corolla SR5 Wagon 4WD 1989, 314 000 km, two-tone green, 5 spd, perfcet condition, repainted in 2003, Factory A/C, perfect shape.<br><br>Tercel 4WD Wagon DLX 1987, 230 000 KM, PARTS CAR, Light Blue, 6-spd, front chassis rusted, has broken, Good Engine, Good Trans, Black Deluxe interior, My Spare parts Car<br><br>WE FRENCH CANADIANS LOVE HIGH MILEAGE TOYOTA'S
Tercel4wdQuébec
Hey TJ, where did you got that A/C kit????
GTSSportCoupe
Post by GTSSportCoupe »
My tercel also came with an aftermarket installed a/c kit. I have the instructions for it too that I can scan in if anyone is interested.
Current:
91 LJ78 Landcruiser EX5
95 A32 Maxima SE
Former:
87 AW11 MR2 Smallport 4AGZE
93 Taurus SHO ATX
86 AL25 SR5 6spd 4wd
90 AE92 GTS
82 KP61 SR5
85 MX73
87 AE86 GTS 4AGZE
85 AE86 GTS
83 AL21
