Rear lower seat hinges
Im looking for rear lower seat out side hinges for an 86 wagon. Anyone know where to get. Local junkyards here don't have anything that old.
Re: Rear lower seat hinges
just noticed your wagon is a 2WD and i'm not sure if the 4WD hinges are compatible. i believe someone mentioned that the rear seats are different in the 4WD due to having to make room for the driveshaft to the rear axle. not sure but thought i'd mention it.
there are two 2wd wagons. one '86 and one '83, in the local yard, do you want me to get both the outside hinges (these are the ones on the flip up back correct?) PM me and I will let you know what I find.
Yeah that the flip one , It make the whole cargo floor flat , not like T4WD,You right dlb , it because of drive shaft .Petros wrote:there are two 2wd wagons. one '86 and one '83, in the local yard, do you want me to get both the outside hinges (these are the ones on the flip up back correct?)
Lee250,
okay, I got both of the outside hindges for you, they are like new. And they are different from the 4wd, but these are from a 2wd wagon. You do not need the inside hinges? How did your hinges get damaged?
PM me your address or to arrange to come by and pick them up if you are local.
